The bulk action feature offers several options to streamline processes, including Add To Deal, Assign Owner, Update Field, Delete, and Export. These options allow you to efficiently manage multiple items at once, reducing the time spent on repetitive tasks and enhancing overall productivity in CRM management.
Bulk-adding products to a deal streamline the process by handling multiple products at once, which saves time and reduces the risk of errors. It ensures consistency in product details and pricing, facilitates quicker updates, and improves overall efficiency in deal management.
Assigning owners to several products simultaneously provides clear accountability, saves time, and minimizes errors. This approach streamlines management and enhances coordination, resulting in more efficient product oversight.
Updating bulk fields involves modifying specific attributes or data points for multiple items simultaneously within a system or database. By selecting multiple items and applying changes to designated fields in one action, you can ensure consistency, enhance accuracy, and save time compared to updating each item individually.
Note: A validation message will appear if a field is designated as required after the product is created and the user tries to update any other field.
Multi-item deletion is the process of removing multiple records from a system or database in one operation, streamlining data cleanup, and simplifying dataset management.
It will open the confirmation popup and ask Are you sure you want to delete the selected products?
Note: After deleting the products, they will be moved to the Recycle Bin, where they will be retained for 90 days.Exporting bulk products entails transferring a large number of product records from a system to a single file, such as CSV, XLS, or XLSX. This file can then be used for offline access, analysis, or collaboration with other systems and applications.
